Carista abs codes help please
Vogon42
Hi all.
T6 150 4motion: I have ABS and skid lights up.
Carista shows codes 00091(Signal ignition key puts) and 04199 (manufacturers specific code: Rear lights).
Live data shows Rear Right wheel speed as zero when others all the same and real speed. I guess the right rear wheel sensor or wiring is faulty.
Any ideas why Carista shows rubbish please or is it hinting that the right rear earth or wiring may be faulty rather than the sensor?
TIA.
Yes, all of the above could be true, but I guess you can look to see if the lights are working?
Yuou can also clear the codes and see if just the wheel speed sensor remains?
They do go, I just recently had to change my right rear WSS.
Thanks Loz. Lights are working and I cleared the codes and they came back immediately. Do you know of any tests that would check the wiring?When you changed it did you use any special grease like the VW workshop manual says?
