meza Member T6 Pro 16 Dec 2023 #1 I’ve got a problem setting the time on my T5.1 The left hand button on the speedos doesn’t do anything, so I can’t get into clock set mode. The right hand button works - in so far as holding it down clears the trip mileage. Any ideas? I’m 11 hours and 40 minutes early for everything currently.
Craig. Craig T6 Pro 16 Dec 2023 #2 Remove the clocks and strip off the casing, see if it's just the push button that's broken or if it's a problem on the board. 2x torx bolts accessed from underneath and then it pulls out with 1 plug on the back. If you time this right (midnight) then you can reset the clock by unplugging the clocks and then plugging them back in LOL
meza Member T6 Pro 16 Dec 2023 #3 Hahaha I love that suggestion. Bit of late night DIY coming up… Thanks
Pauly Senior Member VCDS User Admin Moderator 16 Dec 2023 #4 And if you ever need to disconnect the battery in the future make sure you do it at midnight !!
