Spring compressors ??
I know THQ was doing 1200 for the b14s fitted.
TBH you’re probably right but for the money for a professional to do it and it then have some sort of guarantee I’ll stick to the easier bits but thanks for your enthusiasm towards my manual skillsYou’re capable of both
I have managed to get a 3 month old set off the forum and get them next month.
After fitting they obviously need set up what is involved in doing this is it as simple an measuring from the centre of the wheel to the top of the arch when it is on the ground then adjusting accordingly?. Or is it more complex than that
I haven’t seen the B14s before so apologies if this is a daft question . Do they have measurement marks on them or do you fit them and then put the wheels back on try and get it on a level surface measure them a and then remove wheels and alter accordingly?.If you want it all the way down, keep the rears on the bottom of the thread (wound all the way down) and the fronts up 15mm, that should mean she’s level ! But depends what weight you have in the back.. mines empty pretty much. But I suppose if you always work off, whatever you raise it at the back by, add that “mm” measurement to the front springs which are already set at 15mm.. so could be 5mm on back meaning 20 on front ?
That looks simple enough. Thankshow to adjust coilovers - YouTube
PLENTY of americans giving it their best shot mate - i have BC coil overs on my track car, so when i first got them i watched a few of these.
The garage just Left me a message and it will cost £150 to fit them which I think is ok but they told me I might need extra links? I haven’t a clue what that means?.That looks simple enough. Thanks
