Mote365
Hi All,
I've been looking around for just the right rack, lots of misinformation about on clearance and so forth, plus I've got 2 downhill style eMTBs so they're heavy, wide, 2.8" tyres and a handful to mount on most racks. My van has the removable Westfalia hitch.
The first big hurdle is a rack where the tailgate clears the clamping mech that goes on the tow hitch. here are ones I tried directly...
Thule Velopsace XT2 will not do that. The clamping mech is hit by the tailgate. This model has a clamp set across the rack rather than in line as you look at the rack. That causes the issue.
The Thule Easyfold XT2 also does not work. Tailgate will not clear. Same issue with the clamping mech even before we talk about tailgate clearing the rest of the rack, which it won't.
Thule Velospace XT3. This does fit the van. The tailgate clears the clamp mech and the rack on its max tilt setting. But I didn't buy that as it has a 19cm spacing between rails, this made the bikes tight, just touching when moving along, wasn't super pleased with that, and didn't want a three bike carrier really.
Enter the Atera Genio Pro folding carrier for 2 bikes (and a third optional rail, which also gives you more weight carrying ability by 5kgs).
This tailgate clears the clamping mech by about 2cm. Then you can change the tilt position to almost horizontal and this means the tailgate clear the rest of the rack and my typically massively wide MTB handlebars—but I'd turn the inner bike's handles as they're scary close to rear window when upright, a good tap and who knows how the glass would hold up
This rack also has 21cm between rails which means no fighting with the bikes, perfect clearance for 2 downhill eMTBs with big forks.
You can add an additional rail to carry a standard bike up to 17kg and it also means it ups the whole racks weight to 65kg.
Did I mention it's cheaper than the Thule too?
Bonus.
It looks well built, folds so we can put the rack in the van when parked up if parking is tight, so I'm looking forward to using it...
Just thought I'd get this out there as there were recommends on clearances that didn't work out for me at least.
Jeff
Jeff
