Audio Upgrade Stage-2 - Vibe Micro Amplifier Plug & Play - How I Done It -
I am looking to purchase one of these micro 4 channel amps. However, before doing so, I wanted to confirm that it could be powered off the head unit (as advertised).
Now, I must be missing something, because when I made enquiry of a reseller, they advised that the micro amp draws about 20 amps of power. The fuse on our head unit is 15 amp. How can that work?
We do a alternative plug and play amp, can be configured for factory or aftermarket headunits, in stock
I've just done similar to this but with a Focal 4.320 I've got the basic composition media radio so I placed the amp inside underneath the radio towards the front in the empty din slot. Now I'm wondering if it might all overheat in there. Do you think I should move it out of there? I did want to cable tie it in behind the glove box like dell did but there's already something in there. Might get someone to take a look at it to make sure it's safe.
Hi all, where are you buying the adapter looms?
I’ve a T5.1 2013 with standard Headunit, I’ve got ground zero vehicle specific 8” components and tweeters in the doors. I’ve bought the vibe powerbox but silly me didn’t get one with the VW loom.
Hey mate, I'm in the same situation - Got the vibe amp but didn't get the VW loom. Did you end up sorting one? Could you send me a link to the correct one if so? I've seen a few generic quadlock to ISO harness around, but unsure exactly which one I need, how many plugs should it have?
Hi all, what gain have you used? I have just installed the same amp and speakers as described in this thread (Powerbox plus 8" Blam (no sub)) and I have factory rears and factory discovery media head unit. Right now I have the front gain at 50% and the rear gain at zero. I haven't tested it for sound quality yet so just checking before I put everything back together when I'll no longer have easy access to the amp.
Think I'm about 50% using the factory discovery media headunit.
My amp it tucked up above the glovebox, so out the way ATM.
I'm not looking to beat SPL comps just a boost to drive the Blams decently.
Sorry to bring up an old thread but I've just bought this amp and an upgrade speaker kit to match. I’ve got a discover nav which is rated as 4x20w yet there are comments here saying this amp is barely more even though it’s rated at 4x 65w? so I’m confused on that point.
secondly has anyone recently installed it and got any more install pictures? I also don’t want to cut out the plastic but ramming wires in the back is horrid and bothers me more
I struggled with fitting the adapter loom , but baulked at taking a multi tool to the rear plastic part- my solution was to feed the original loom ( including aerial feeds ) back through the hole on the rear right side of the head unit slot. It can the be fed through to the right and enter the slot from underneath ( behind the heater controls) where there is plenty of space to plug in the adapter loom and store the connectors
Simon
@Sim60 - Hi Simon, you must have had to split the aerial and non quad lock cables from the larger factory loom and route them back in to the head unit slot? - or what way did you approach this? - How much of a squeeze is it to get the quad lock block through the slot on the rear right of the head unit slot? Thanks in advance..
Is this still a good option or are there better options now?
I love the idea of it being plug and play, no messing about with RCA cables etc.
I think with mine having the poverty spec headunit, there should be plenty space in the dash for the amp and the loom.
We offer plug and play speakers and hideaway amps From Kenwood, phoenix gold, Focal
hello,
wondering if anyone can help me with this.
Recently fitted the vibe amp with the plug n play harness. The issue I'm having is that it switches on and off randomly when the head unit and ignition are off. The speakers randomly pop, and now it's draining the battery and annoying the Mrs when it won't start for her.
Any help would be appreciated.
hello,
Mine was the same, just sent it back. Focal also does p&p amp for VW.
Unfortunately, because I work away, I will be well and truly out of time for sending it back. No harm in trying, I guess. Or I just use it as an excuse to get the Alpine Halo
I would get Match UP DSP with Bluetooth HD module.
Got one of these Vibe amps on the way to me, already have dead doors, Gladen speakers and tweeters in the front (which is a massive upgrade, thank you @Dav-Tec) also Hertz 6x9 speakers in the rear panels.
Amp not fitted yet but my sound (t6.1, composition colour HU) still has a harshness to it (treble all the way off, mids half off, bass half up). I appreciate the Vibe amp will boost volume and drive the speakers 'better' but as it's a high level input to the amp the amp in the HU will still colour the sound somewhat? Will I still have the harshness? Do I need to go for a DSP amp perhaps?
I’m afraid Adding the amp will exacerbate it even more, the vibe is also not the best quality .
The factory head unit is EQ’d to death , so no matter what you do with the audio settings it will not make much of a difference, also the bass rolls off when you turn it up.
There is a trick done by coding on these units that does help
But a dsp will be the best
Thought that might be the case, appreciate your input.
