Hi ...I have a T32 too and seem to hitting my head against a wall trying to source 19" alloys and tyres. I like the radi8 r8s5 in dark mist but I cannot find out what load rating they are....I also like the Veeman V-FS27R in gloss graphite, but again cannot find the load rating....would 19x9.5 fit on the front and rear with 245/40/19,s as I'm not to keen on the staggered look?
As @Walski above ,but again you can not get a 245/255/45/19 tyre with a 103 r or above . so again no good for a T32
@StudleyGlass UniRoyal do a 255/45/19 with a 104 rating
Hi @gmaster, take a look at page 1 of the "operation B14 has commenced" there are a number of pictures on there which will hopefully give you the views you seek.@DaveyB have you got a picture you could post of how your sportlines look please? I am running 20's, but may go to 18"'s as I'm thinking of getting a caravan and I don't want to put too much strain on the gearbox. Thanks.
Understand what your saying but who cares once your into the realms of a van you need an extra load tyre in general I have said in the same message that a 100y would be perfectly load rated for a t32 weighing 3200kg.I'm not really sure where you've got this information from. A T32 should be fitted with a 103 rated tyre as a minimum.
Fitting higher rated tyres does not increase the permissible gross weight of the vehicle, so who told you that a 103 tyre would increase the vans load rating to 3400KG?.
It's very simple, you take the highest maximum axle loading from the vehicles weight sticker, divide this by two and ensure that each wheel and tyre is rated to that figure.
Yes in my eyes this looks perfect laced with a 19inch wheel. The only thing I would say is that its a standard VW wheel which probably won't be as light as some of the bespoke alloy wheel cutters and the finish of the wheel won't be as precise and will need more balancing than other aftermarket sets but even still is a nicely done job.
