Hi all, pulling out my hair here. I have an after market camera kit that works as it should off a battery with a 12v trigger as if from a reverse light. The VW setup is alien to me. I have run the cabling from rear to the front left A post as instructed but not sure if the wiring needs to go elsewhere due to the canbus setup. Also in running the cable to behind the glove box, the airbag light is now on even though I was extra careful removing the side panel.
I need a 12v+ on the ignition, a 12v-, and a 12v+ trigger on reverse. HELP it’s twisting my melons man
