Shreknomore
Hi all
My adblue has not reset after refill , is it possible through one of the systems on this thread?
Please check the actual AdBlue level and remaining range estimates BOTH in engine and dash display. See belowso obd 11 arrived.
Hmm... ECU tells the engine has been running only 5 minutes?was driving more then 30min
IDE00078 | Time since engine start | 305 | s |
@Gordon Bennett. Maybe I’m being even thicker than usual but do you mean that you added adblue (ie. not diesel) to more than 2/3rds full? If so how much adblue did you actually put in please?I had this issue after I topped my ad blue up last week. It was the old 650 miles to non start message. It didn't reset so after reading a few threads I added diesel up to more than 2/3rds full, took it for a 8 mile run and it reset.
Strange - the labeling in OBDeleven is exactly the same as in VCDS (as in the post).The only things I could find regarding mmi's post are in attached pictures.
01-ENGINE
Remaining vehicle distance until reducing agent deficiency
Reducing agent fill level sensor act. value
17-INSTRUMENTS
Urea operating range
Nope, not a jot, but I read a couple of forums, put some more fuel in as suggested and it worked (after driving around for days with the countdown getting lower and lower). It literally took less than 5 minutes to reset after I filled up with fuel and drove about 3 miles....@Gordon Bennett. So do you believe that putting more fuel in has an effect on the adblue readings? That's a genuine question from a mechanically illiterate numpty!
