Ad blue p20eb00 fault
Druzis
Maybe some one had similar problem as mine p20eb00 fault in engine ecu. It all started when i added the ad blue to the car. After that came the p20eb00 fault. Maybe there is solution to this problem? I've read all the post about the ad blue problems but it seems that different problem in my situation because of different fault code. I retrofitted water heater recently maybe i codded it wrong and it could affect this problem(it works like it supposed to at the momment the there is now roof display connected because i'm waiting for new headliner)? The range dropped from 1000km to 850km at the moment.
OBDeleven vehicle history log
Date: 2024-02-23 12:09:53
VIN: WV1ZZZ7HZJH026729
Car: grey t6
Year: 2018
Body type: Van
Engine: CXHA kW ( hp) l
Mileage: 158140 km
Full scan
Control Units: 14
Fault count: 4
Control Units:
03 Brakes
System description: ESC
Software number: 7E0907379P
Software version: 0133
Hardware number: 7E0907379M
Hardware version: H06
Faults:
No trouble codes found
04 Steering Angle Sensor
System description: LENKW.SENSOR
Software number: 6R0959654
Software version: 0070
Hardware number: 6R0959654
Hardware version: H07
Faults:
10 Parking Assistance
System description: PARKHILFE 8K
Software number: 7E0919475AA
Software version: 0212
Hardware number: 7N0919475
Faults:
08 Air Conditioning
System description: Climatic-T5
Software number: 7E0907047AD
Software version: 0708
Hardware number: 7E0907047AD
Hardware version: H22
Faults:
17 Dashboard
System description: KOMBI
Software number: 7E0920870S
Software version: 1107
Hardware number: 7E0920870S
Hardware version: H03
Faults:
15 Airbag
System description: VW10Airbag020
Software number: 7E0959655G
Software version: 0018
Hardware number: 7E0959655G
Hardware version: H08
Faults:
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Software version: 0752
Hardware number: 7E0937090C
Hardware version: H82
Faults:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
Faults:
5F Multimedia
System description: MU-S--ER
Software number: 5K7035200L
Software version: 0449
Hardware number: 5K7035200L
Hardware version: H41
Faults:
61 Battery Regulation
System description: Batt.regelung
Software number: 7E0907534
Faults:
69 Trailer Control
System description: Anhaenger
Software number: 1K0907383H
Software version: 0130
Hardware number: 1K0907383G
Hardware version: H12
Faults:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090C
Serial number: 4000 184170985
Faults:
04194 - Vehicle status with insufficient voltage
static
priority - 3
frequencyCounter - 1
drivingCycle - 42
km-Mileage - 158141 km
01 Engine
System description: R4 2.0l TDI
Software number: 04L906056KL
Software version: 6166
Hardware number: 04L907445
Hardware version: H02
Faults:
P20EB00 - Reductant Control Module Power Relay
De-Energized Performance - Too Late
static
Priority - 2
Malfunction frequency counter - 0
Unlearning counter - 255
Unknown ambient data - 000000004D3E622CD471209628445400C33B4E00007027000029AA0083197A00D541D602
date - 2073-01-25 00:03:03
P056200 - System Voltage
Low Voltage
static
Priority - 2
Malfunction frequency counter - 4
Unknown ambient data - 000000004D3D622D2A712096283F6500003F6403E8446A009244A7000020290004F40B632097000041C80041C90041C700
date - 2073-01-25 00:01:02
18 Parking Heater
System description: STH-T5GP2
Software number: 7E0963272A
Software version: 0007
Hardware number: 7E0963272A
Hardware version: 002
Faults:
U112100 - Databus missing message
static
Priority - 6
Malfunction frequency counter - 1
Unlearning counter - 42
Operating condition of parking heater - Off
--- - 71
Coolant temperature of parking heater - 27 °C
Coolant temperature - 36 °C
Engine running status - Not recognized
Fuel level - 46 L
Heater output - 0 W
date - 2073-12-25 00:07:43
0-02-05-8836989d77d620317d0e23a8531b3a1c69ae46007375b2a01577c311566c21ee_f266b0547b1100a7.jpg
0-02-05-29016150f148a2901109f53603e720d0150ce9e36125a9bad59826e4ebbc0447_2b5f1bef4133a798.jpg
  • Vw t6 new.txt
Well you have
P056200 - System Voltage Low Voltage
Low voltage can cause all kinds of issues so give her a good charge first, then clear the faults and scan again
I have already deleted adblue system on my car. I tried replacing a reductant power relay, Adblue tank itself. same fault was so the most easy option for me was to do a delete for reductant system.
Car: grey t6
Year: 2018
Body type: Van
Mileage: 158140 km
Full scan
Control Units: 14
Fault count: 4
Control Units:
03 Brakes
Faults:
Faults:
Faults:
08 Air Conditioning
Faults:
17 Dashboard
Faults:
15 Airbag
Faults:
19 Gateway
Faults:
25 Immobilizer
Faults:
5F Multimedia
Faults:
Faults:
69 Trailer Control
Faults:
Faults:
static
priority - 3
drivingCycle - 42
01 Engine
Faults:
static
Priority - 2
Low Voltage
static
Priority - 2
18 Parking Heater
Faults:
static
Priority - 6
--- - 71
Fuel level - 46 L
Heater output - 0 W
Hi,
Did you ever solve this problem? We have the same fault code on our transporter.
Car: grey t6
Year: 2018
Body type: Van
Mileage: 158140 km
Full scan
Control Units: 14
Fault count: 4
Control Units:
03 Brakes
Faults:
Faults:
Faults:
08 Air Conditioning
Faults:
17 Dashboard
Faults:
15 Airbag
Faults:
19 Gateway
Faults:
25 Immobilizer
Faults:
5F Multimedia
Faults:
Faults:
69 Trailer Control
Faults:
Faults:
static
priority - 3
drivingCycle - 42
01 Engine
Faults:
static
Priority - 2
Low Voltage
static
Priority - 2
18 Parking Heater
Faults:
static
Priority - 6
--- - 71
Fuel level - 46 L
Heater output - 0 W
Hi,
Did you ever solve this issue? We have the same issue and fault code with our transporter. Would be really good to know what the problem is and if you have solved it?
Thanks in advance
James
Hi,
Hi,
Thanks in advance
James
Sadly no, i did the adblue delete. With all the system left in the car. It’s only programed out.
Ok thanks for coming back to me. I think I might have to do the same. So frustrating. Did you take this to garage to be deleted?
It’s “programed out” (don’t know how to call it corectly) all the adblue system parts are still left in the car. Reductant system is turned off in engine ecu by the diagnostic guy who came to my place and done it like in 10mins and took 80€ from my pocket…..
Me too. 5 visits to stealers so far and no solution although codes are currently only pending
