Faults after attempt installing multifunctional steering wheel
AllanAM
Hello, I've tried to install a multifunctional steering wheel and bought a coding dongle from kufatec. After installing the wheel and using the coding dongle all faults occured. My cruise control doesnt work anymore and my horn doesnt work anymore and my start stop system.. The coding dongle changed the bytes i think off the long coding. Can someone help me with this, I've made an obd scan off the van and this is what came out.
Code:
OBDeleven data log
Date: 2023-01-16 17:50
    VIN: WV1ZZZ7HZLX011037
    Car: Volkswagen Transporter
    Year: 2020
    Body type: VAN
    Engine: CXGD 66 kW (90 HP) 2.0 l
    Mileage: 59791 KM
01 Engine
    System description: R4 2.0l TDI
    Software number: 04L906056SD
    Software version: 9942
    Hardware number: 04L907445M
    Hardware version: H01
    ODX name: EV_ECM20TDI03004L906056SD
    ODX version: 004007
    Long coding: 001140144334050900000000000000000000000000000000
    Trouble codes:
        U021200 - Lost Communication With Steering Column Control Module
            static
                Date: 2023-01-14 00:18:51
                Mileage: 59472 km
                Priority: 2
                Malfunction frequency counter: 30
                Unlearning counter: 255
                Engine speed: 0.00 1/min
                Normed load value: 0.0 %
                Vehicle speed: 0 km/h
                Coolant temperature: 65 °C
                Intake air temperature: 21 °C
                Ambient air pressure: 990 mbar
                Voltage terminal 30: 11.851 V
                Dynamic environmental data: 20962844D000003D8000203C0007210F0008
        P164700 - Checking coding/versions of control modules in drivetrain
            Intermittent
                Mileage: 59472 km
                Priority: 2
                Malfunction frequency counter: 9
                Engine speed: 863.50 1/min
                Normed load value: 27.5 %
                Coolant temperature: 81 °C
                Intake air temperature: 22 °C
                Ambient air pressure: 970 mbar
                Voltage terminal 30: 12.789 V
                Dynamic environmental data: 2096282116000020330000203C000141690000416B0000416A000044D00000
You’ve changed the airbag loom and added the extra wires from the clock spring to the BCM and ignition live?
No i didnt do that yet. I just put the new loom without adding extra wires. But its programmed like it has. I just want to put back everything to normal. I already have the normal steering wheel on it with the normal loom but the errors are still there because the coding dongle changed everything.
To get rid of the error you would need to put the coding back to original or complete the installation of the wheel.
How can i put the coding back to original? I dont have the old codes or something. Thats the problem im having now if someone could help me with these codes i would be more than happy.
I’d speak to kufatec. Those dongles can be updated via USB, maybe they can supply a firmware for the dongle that can remove the coding it’s added. Failing that VCDS could reverse the changes. You don’t need the original coding, it’s just a couple of boxes to un-tick.
