ABS FAULT
gerry
France
VCDS User
Hello ,
I change the bcm ( test )and replace the old ....new problem now
just an abs fault thank you if you have a solution
Monday,29,June,2020,09:00:01:43195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH00xxxxx License Plate: 29/06/20 H81 01
Mileage: 53060km-32969mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHH006144 Mileage: 53060km-32969miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8440
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005986D9CA8988BB53B-8054
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41346000000190
Coding: 557E409825628484AA76027AA48621D6380000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4525F7F737436A1-806A
1 Fault Found:
0320 - System Function Test Activated
C101F 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 53069 km
Date: 2020.06.29
thank you not easy but it's good
complicated to change a bcm and reprogram
Indeed had this fault code as well (or similar).
After the so-called 'ESP test' which only takes 30 sec fault was cleared. ;)
Reactions: mmi
