albertinno
Hello.
I have 2016 T6 and i want install RVC.
I ordered this camera from here: New VW POLO AW 2018 - Rear Emblem Camera KIT - Retrofit - (I install this inside the door)
Installing the camera wiring was easy.
My car radio is next : 5C0035680G
But the problem now is that when I put it in reverse, the camera opens, but the picture doesn't appear.
I have coded two things:
block
5F - Information Electr.
byte no. 19 = byte no. 4
block 10 pdc = byte 2 rear view camera installed
But nothing. Does anyone have any ideas.
Autoscan
block
Autoscan
Code:
Monday,16,January,2023,20:18:32:00685
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64) HEX-NET CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Dealer/Shop Name: Autopaja Tuusula OY, 0400806776
Workshop Code: 123 12345 012345
VIN: WV1ZZZ7HZHH104993 License Plate: NMN-348
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 22 25 37 5F 61 69 0B
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KJ HW: 04L 907 445
Component: R4 2.0l TDI H02 3770
Revision: 23002001
Coding: 00194014432601090000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM20TDI03004L906056KJ 004004
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 7F4E0A5BE6FFD1753A-802A
VINID: 9E606AAAA1D8A986010042490CA8451BE2
1 Fault Found:
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 43496000000761
Coding: 517E8098256284828A7E017FA48521B6780000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FCE4A5BA67F11757A-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 05121613472028
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB0F75FE1F5D87D31-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73A6D66BDAB785154E-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 347160709
Coding: 62A0303A0A21203201200F742CEB8E540F80708F60466D60320400220800
VCID: 2A180B0F45FD84DD3D-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 111216 04 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 003 0653
Serial number: KU0KU030111663352776
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 003 0653
Serial number: KU0KU007121663425562
Coding: 1400A0
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32961631400408
Coding: 31800A
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 43C646ABCA9775951E-8016
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag020 H08 0018
Revision: -------- Serial number: 003V30036N0Q
Coding: 000000000000000000000000000000003230
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A383B4FBD5D345D4D-806E
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042205
VCID: 689CB1079B7176CDEB-803C
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00003.11.16
Coding: 0501
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 54E475F73FF9E22DB7-8000
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A98CB0F8D7D44DDFD-803E
Address 37: Navigation
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H22 0245
Serial number: VWZAZ2S8247404
Coding: 065700013C00000001110000000808001F0100D4002001008F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 200CE9273BC14E8D63-8074
2 Faults Found:
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 233
Mileage: 179911 km
Date: 2068.14.18
Time: 19:43:45
Voltage terminal 30: 11.6 V
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 233
Mileage: 179911 km
Date: 2068.14.18
Time: 19:43:47
BAP-BAP_Function_ID: 02
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B7A73
Shop #: WSC 18346 003 1048576
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001612020042
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: TCV 301 004 0 HW: TCV 301 004 0
Component: ANHAENGER_MODULE TC 0030
Coding: 0000001
VCID: 45C258B30CA34BA530-8010
1 Fault Found:
02563 - Trailer; Right Tail Lamps (M61)
011 - Open Circuit - Intermittent
End----(Elapsed Time: 01:41, VBatt start/end: 11.9V/11.3V. VIgn 11.3V)-----
