VCDS pre-code fault scan!
huib berger
Dear all!,
Your help is appreciated! As I wrote in my first post a week or 2 ago , I recently purchased a 2017 Multivan TDI 150HP DSG. I changed the headlamps to H7, added Front Fog lights. In addition I did (my very first) coding related to those items using VCDS. I'm totally new to VW (my other car is a Volvo XC90T8)
So far so good….or I thought…..
Only after all that I realised that I should have made a full scan and system backup first …. call me a stupid foreigner(!) …..but I did not…..
So instead I did that scan only today …. and unfortunately found some messages (please see later) -> PANIC!
I don’t know if these faults already existed before my ‘work’ or not. I tried to reset, but they won’t go away…. Now as it is still under warranty (by the dealer, not by VW) for a few more weeks I would like to sort these asap.
- Could I have caused these faults (e.g. when installing the wires in the BCM or by accidently upsetting the code somewhere)?
- Are these 3 items related ?
- What can I do?
- Strange: The date in de message is in the year 2032……. Is that the car’s system date? Can that be corrected in any way?
For your info : There are no warning lights on the dashboard, setting the tyre pressure seems is accepted by the system and confirmed with a beep. The car runs absolutely fine, no issues there.
Thank you for any suggestions, help, guidance etc.
Best regards from the (rainy) Netherlands
Huib
The Information found:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
69-Trailer -- Status: OK 0000
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 140B010300
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_Kombi_DUS_VDD_RM09 A05733
ROD: N/A
VCID: 39791414B8C05887A0-806C
No ASAM data for: "EV_Kombi_DUS_VDD_RM09" (VW36 *)
1 Fault Found
12658432 - ROD - Unknown Error Code
- 00 [009]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 38475 km (it is now at 38500)
Date: 2032.14.07
Time: 09:30:56
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
Shop #: WSC 02737 534 108253
VCID: 68DF81509BEA110F0F-803C
1 Fault Found
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 38475 km (now 38500)
Time Indication: 0
Date: 2032.14.07
Time: 09:30:57
Address 65: Tire Pressure
Cannot be reached
Address 65 should not be present ?
If you have added this then you should go back in and remove it, to do this go into the can gateway module 19, click on installation list then untick box 65 and save it
this will hopefully clear both fault codes
I didn’t think direct TPMS was available on transporter. If your van is not supposed to have it, go to the CAN gateway and remove the tick from 65 Tire Pressure in the installed gateway list
Reactions: mmi
VCDS has logged all the changes in directory C:\Ross-Tech\VCDS\Debug
There are two files, one for coding changes "CodingLog.CSV" and one for adaptation changes "AdpLog.CSV".
Original codings & adaptations are - obviously - on the first line for each module, e.g.
That is handy to know..i always scan/backup before making a change...but its good to have another means of reviewing the changes.
All sorted! Thank you all very much for your contributions! A bit of a steep learning curve...…., but very happy now!
Thanks again!
Thursday,09,January,2020,22:23:47:39370
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZHH137543 License Plate: ZD-166-S
Mileage: 38490 Repair Order: 6789
Gateway Installation List: 7E0 909 901
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
