PPF you can 'float' in to position with a water spray unlike most wrapping vinyls but tends to be a fair bit pricier per sq. metre.
Applying wrapping vinyl isn't that difficult if you use a decent air-release film, take your time and generally work from the centre outwards. Apply a small amount of tension to it to avoid creasing as you apply with a foam block or rubber squeegee.
