Hi all I'm looking for some help please
T6 cxha 150 ps t30 120k miles
Yesterday when driving on the Dual carriageway my van cut out I lost power and managed to get onto the hard shoulder.
I attempted to restart with no joy it was cranking over but would not attempt to fire up.
No engine management light and I also did a diagnostic scan as I had it with me but not one fault found.
AA sent out a local recovery company who also scanned the vehicle with his autel scanner but also found no fault codes.
Checked timing belt was tight and intact all seems ok.
I have removed the fuel feed line at the fuel filter, turned the ignition on and there was no fuel coming out not even when cranking it over. The in tank fuel pump was not running
I checked on live data rail fuel pressure 35600 kpa which i believe is 365 bar.
Today I have tested the lift pump relay as it was not clicking. I had 12v at the common of the Normally open contact.
I tested the ecu was switching 2vdc on the yellow wire I believe the negative pin of the relay coil.
But I wasn't getting 12v power at the relay coil positive terminal so I traced this back to the fuse box and I didn't have 12v as the fuse was not pushed in.
Once I inserted the fuse back into the fuse carrier the relay started operating and low pressure fuel pump was delivering fuel to the fuel filter as it should.
I have run the lift pump to fill the fuel filter then cranked and cranked the engine over but still won't start, I have tried getting it to prime fuel through with easy start and it will run on easy start but cuts out as soon as you stop.
Checked the injectors are opening on live data
Cam and crank sensor are ok I believe
Egr valve opening
What I don't get is if the low pressure fuel pump wasn't delivering fuel to the fuel filter how was I getting 365 bar of pressure at the rail???
what I'm thinking could the rail pressure sensor be faulty and causing the fuel to return to the tank
Any help or suggestions on where to turn would be appreciated thanks
Egr valve opening
