Hello,
Since my strut mounts are making noise and the van has 140,000 km on it, I'm looking for new shock absorbers with a slight lowering, no more than 40 mm. I tow a 2000 kg caravan on vacation.
I'm from Germany and enjoy reading along here.
In Germany, Bilstein products are very popular, but you often read that the B6/B8 models are too stiff. Eibach springs are also commonly used, which always require TÜV approval.
Here, Koni/H&R have good reputations.
VW T6 Multivan, front-wheel drive, 5-speed manual transmission, 3000 kg, 1610/1575 kg axle load.
My question is, what should I use?
Koni Special Active 8705-1392/8205-1009
Koni Special 87-2645/82-2542
H&R 29270-4 (from 1551/1551 kg)
H&R 29270-2 (from 1551/up to 1550 kg)
Then there are also yellow Koni shocks from Deimann in Germany, externally adjustable at the front, 2 cm shorter, supposedly very comfortable, but very expensive, around €1100.
I read that CRS Suspension produces its own springs in different stiffness levels. Very good, unfortunately, there's a TÜV (German vehicle inspection) issue in Germany.
Please excuse my Google Translate English.
Thanks from Germany.
Regards
Regards
