Which Dash Cam Fitment ?
JamieM
Hi folks, long shot but wondering if any of you know which dash cam this base is from?
Thinking of getting a dash cam and would make sense to use this as it’s already stuck to the windscreen, if I can identify which dash cam it’s for …
Thanks, I tried the google image search and got the same thing, but discounted that as I thought it unlikely the previous owner based in Scotland would have fitted a dashcam that looks as if it can only be brought in Asia (though not impossible I guess). Can’t really compare like for like as all the links for that brand are in Japanese 😬
If you fancy changing to another dash cam I have the Fitcam X which does a good job and looks well matching the car trim.
Been looking at these, was fitting straight forward?
I need a black one with the camera offset to cater for auto dip high beam
Any discount codes flying around?
Fitting is straightforward, I wired mine back to the fuse box rather than the rain sensor which they suggest . Depending on your van T6 or 6.1 they do provide different colours to match the OEM trim
I did email them and they came back very quickly with the exact part number which was impressive
what is the advantage of going back to fuse box?
did you bother with the anti glare lens attachment?
cheers
Just to let anyone know who’s interested, I cleaned the image up and redid the google pic search, and this time it worked, seems the mount is from the dashcam below, but apart from a few on eBay they don’t seem to be readily available in the uk, so think I’ll try and get the mount off the windscreen and go the FitcamX or Wolfbox route …
cheers
Back fuse box using a spare switched supply which is infinitely better than piggybacking to the rain sensor. That way I have a stand alone dedicated supply.
