Where To Break Through The Engine Bulkhead
col661
Hi all. I'm about to embark on a split charge system hosting a CTEK under the drivers seat with a 110amp battery. Is there a common breakthrough area under the bonnet to get the main live charging cable through the bulkhead to run under the carpet (highline) to present under the drivers seat?
On my converted T6 there’s a hole under the scuttle panel, just above LH front strut top mount. That’s where the cable for my second battery is routed, the people who converted mine had forgot grommet, I sorted that today while doing suspension.
It looked to be a factory hole as was very clean cut & painted.
