Vw T6 support hanger bearing replacement
baldonion
Hello folks,
does anyone know if it is possible to simply replace the support hanger bearing on an OS drive shaft?
The hanger is available separately but i'm wondering if you can slide them on to the existing shaft (once its removed from the vehicle) without dismantling the cv joints?
It looks like you should be able to slide them on from the 'stub shaft' end?
Anyone done this? saves replacing the entire shaft
Thanks.
