Victron Energy Orion XS 12/12-70A DC-DC Battery Charger
Engineered from the ground up, the Orion XS 12/12-70A is Victron Energy's latest next generation DC-DC charger that redefines charging in campervans, motorhomes, and other leisure vehicles with a smart alternator. With huge improvements over the previous Orion-Tr Smart DC-DC charger, this device not only ensures the latest in battery charging performance, but its host of protection features also guarantees the safety of your system.
This higher output 70A model is ideal for the latest generation of lithium LiFePO4 batteries that can handle large charging currents, offering significantly faster re-charge times. The output charge current can be set by the user and innovative cooling technology provides a 98% efficiency, enabling a lightweight and compact, but powerful charging unit. Victron's adaptive 4-stage charging algorithm alters the absorption time to suit the depth of discharge to prevent over-charging, and the user can select from 8 pre-programmed charging algorithms or create a fully customisable algorithm to match the battery manufacturer's charging requirements
The Orion XS 70A features miniature fans mounted on the underside of the unit to aid cooling, allowing it to produce the full rated output of 70A up to 40°C. Multiple units can be connected in parallel to increase charge output, and it can be used in fixed-voltage power supply mode with a user-configurable output of 10-17V.
Please note: The fan assisted cooling means that this unit has a protection rating of IP20, so should only be installed in dry environments.
The unit is fully configurable via Bluetooth using the VictronConnect app, and features a VE.Direct port for remote monitoring and control capabilities via a GX device, allowing it to integrate seamlessly with the rest of your Victron system.
Features
- 70A output (ideal for lithium LiPFePO4 batteries)
- 'Smart' or standard alternator compatible
- Separation of starter and auxiliary batteries
- Adjustable charging current in 0.1A increments
- Engine shutdown detection
- Bluetooth smart enabled
- Adaptive 4-stage charge algorithm
- Fully programmable battery charging profile
- Suitable for all battery types
- Automatic temperature compensated charging
- Comprehensive electronic protection
- Can be wired in parallel to increase charge current
- Power supply mode (user-defined, fixed output voltage)
- Remote on/off
- VE.Direct port for connection to Cerbo GX or Ekrano GX
See below for a full description of improvements over the Orion-Tr Smart DC-DC chargers:
Increased power with user-selectable charge current
The Orion XS can deliver 70A of charge current (1000W), providing faster charging and making better use of more powerful modern alternators. But the real innovation here is that Victron has provided the ability for the user to set the charge current to meet their requirements (in increments of 0.1A). This is a huge advantage for users wanting to future-proof their charging system if, for example, they one-day plan to add a second battery in parallel, change to a lithium battery (that can accept a higher charge current) or upgrade their alternator. They can run the charger at a lower output initially, and release its full potential later on.
Higher efficiency with much lower heat generation
One of the issues with the Orion-Tr Smart DC-DC chargers was that they generated a lot of heat. Victron has re-designed the electronics in the Orion XS to use an innovative aluminium circuit board cooling technology that provides a staggering 98% efficiency (up from 87% in the Orion-Tr Smart), massively reducing heat generation and making better use of the alternator's output.
Significant size and weight reduction
Due its high efficiency and low heat output, the Orion XS can dispense with a bulky heatsink which means it is smaller and lighter than the Orion-Tr Smart.
VE.Direct port
In addition to connection over Bluetooth via the VictronConnect app, the Orion XS has a VE.Direct port for connection to a GX device (e.g. Cerbo GX, Ekrano GX), enabling local or remote monitoring, configuration, and control of your charger and integrating it with the rest of your Victron system. When connected to a GX device, Orion XS chargers that are are run in parallel can communicate to synchronise their charging stages for more efficient charging.
Larger cable terminals
The DC cable terminal block now accepts cable up to up to 25mm² cross section and features a cable clamp to provide strain relief.
Further information
Important: Please ensure that your alternator is capable of providing sufficient charge output so that it is not over-worked (which may lead to premature failure). We recommend that your alternator has at least double the output current of the attached DC-DC charger, so a 140A+ alternator is recommended if running the Orion XS at its full 70A output.
Specifications
Manuals & Guides
Customer Reviews (0)
Victron Energy is at the cutting edge of power management technology, offering a range of innovative and highly reliable products for every leisure application. This highly respected brand has a wealth of experience in the automotive, industrial, off-grid, marine, energy-storage and telecoms sectors.
