Nice charger . . . =]
most people fit a charger that size in the seat base or kitchen unit on a T6.
as above, you need the DC-DC charger that will use engine power to charge the Leisure battery when you get it fitted.
one of the features we called AUTO VSR that enabled that.
more info here:
Battery Chargers - How I Did It - So its that time of year again, cold, rainy. . . . . . . flat battery =[ This time we look at Battery Chargers. Our vans will most likely come with a AGM style starter battery, for this type of battery we need a "Smart Charger" . . . . but what does this...
www.t6forum.com
DC-DC Charger (for Leisure battery) -- How I Done It -- ************************************************** Dellmassive`s -- "how I Done It" -- Thread ************************************************** Kit List And Stuff -- How I Done It & What I Use --...
www.t6forum.com
Hi, Inspired by @Deaky build post, I was planning on installing a Victron IP65 Smart charger next to the Starter Battery and a 2nd one to charge the Leisure batter (110AH AGM). I've discovered the CTEK D250SE will still charge the leisure battery as long as the volts on the starter battery are...
www.t6forum.com
but you can also do it the other way round . . . . ie - conect your Victron EHU charger direct to the AUX/Leisure battery.
you can then back charge the starter battery.
more on that here:
[Guide] Battery Maintainer (for Starter battery) -- How I Done It -- Right so its that time of year again . . . . . . . . Winter & (Lockdown 2020) The van might be layed up not being used, which will lead to a flat battery in around 3 weeks. The cold weather doesn't help the battery's...
www.t6forum.com
