VCDS users
Hi all i have VCDS also AUTEL IM508 and AP200 add me in the Durham area. I only have 3 vin version but may upgrade as i have 2 VW’s with an Audi coming later in the year. Scan to follow.
New to the Forum and new to VCDS. I recently purchased the VCDS to help diagnose something on another VAG vehicle.
I’m in South East of Ireland and have a HEX-V2 cable with unlimited VIN’s so stick me on the map please.
Will send VCDS scan now.
Hi, I am new here on the forum, own a VW Polo 6R. I am much active on the Polo forum (mypolo.nl). But for all the retrofits I occasionally get some information from the T6 Forum. Am in possession of VCDS HexV2 (Pro) and OBD Eleven. Also in possession of (unfortunately not legal) ODIS service. I am based in the Netherlands. For more info check out: https://vagcodingtwente.nl.
Hi, I am new here on the forum, own a VW Polo 6R. I am much active on the Polo forum (mypolo.nl). But for all the retrofits I occasionally get some information from the T6 Forum. Am in possession of VCDS HexV2 (Pro) and OBD Eleven. Also in possession of (unfortunately not legal) ODIS service. I am based in the Netherlands. For more info check out: Home.
Would be great if we could get you on the map if you want that..
I am from the Netherlands and was wondering if anyone is able to possible help me with an Engine Misfires issue while idling.
Might give you a call later on.
Hello, I would like to be added to the map, I’m in Nelson, Lancashire. I have Hex-V2 with unlimited vins, will send my scan over
After replacing the battery, the van started.
I started looking in VCDS why there are no DRL lights and I must have changed something and the van does not start.
There is no power supply on Fuse 56 from ECU 5A.
I called recovery, there were 30 errors. They were deleted and two remained :) visible in the picture.
I have logs from VCDS before deleting errors and after the deleted errors.
I think it is a bigger issue, please help, I can send the VCDS file,
Location Milton Keynes
A vcds expert told me << the problem is not in the VCDS coding but in the physical lack of connection of the wires >> so I check and some fuses have no power, I go deeper to high voltages 😀, any tips where to look for ECU power?
Does anyone know off hand how to update the member map to show my new location?
Moved from Exeter to Southampton and it still shows Exeter ...... preferred Lat Long is 50.936817, -1.252475 if a mod can tweak it for me .....
It’s set in your member profile area, will take a while to update, think the cron job only runs once a day
Hi Pauly,
Its a week later and still not updated :-(
[The grey blob with the date and time was added by me]
Can you tickle cron to encourage it to like me please 😎
Hello, new to the forum and not long had my T6.1. I am hoping to be more active on the forum now that I have my van. I have had VCDS for 10+ years and recently just upgraded to the HEX-NET wifi. Do I need to send a scan to [email protected]? Location is Darlington, North East.
