TPMS warning an no way too reset even AA cant do it!!
RayC
Tyre testing and development
VCDS User
Hello
I have a T6 67 plate Kombi Highline it has TPMS sticker warning light etc yesterday the warning came on tyres were ok but I've fitted 17" wheels so I read manual on how to reset it says button in glove box but its just a blank, is this correct should it have a button?
next I looked in DIS its not there, called VW assist they set AA he gave up could do nothing
I read on here about adding it by putting D3 in the coding mine is F3 I did put D3 in and the option came up in the DIS to reset it
its crap that I have to do this and I wondered if my van is a misbuild?
could anyone else with highline kombi look to see if they have a button inside the glove box
Ray
The reset for the TPM is in the dash display. Just scroll down and reset it
its not there I have winter tyres but no tpms option
It should be an option in the MFD on a kombi but turned off on a panel van.
If you don't have a full mfd, such as on a startline it will be in the glove box
But its a highline therefore it should have a MFSW therefore it should be in the DIS ??
If you are stuck and there is no option on the MFD for it i would take it to the dealer as it doesnt sound right
100% its not there!
does anyone have the coding info to turn off the TPMS
I have told the instrument panel its not fitted this removes the warning lamp but it bongs once when you key on as the TPMS tyre pressure warning is active I don't want it anyway as the van is used for tyre testing it gets new wheels fitted every 15 mins on a test day so its a PITA!!
Reactions: mmi
if I put D3 coding in it comes up but not the original F3 code
