hi
@Ian_T6
occasionally attach a foldable panel to the CTEK, but also use the same panel to charge my newly purchased Allpowers 372Wh portable power generator.
I've got an AllPowers 372wh. (AP-SS-005)
Awesome 3-in-1 Battery Bank - How I done It - Now normally I don't post specific threads on kit . . . . . . but I had to this time. As some of you may know im into portable power . . . whether that be battery, solar, petrol genny, USB power banks or what ever i love it. The term Solar-Generator...
www.t6forum.com
The Solar input of the ALLPOWERS is "Anderson" "powerpole" or Anderson torberry connectors
ALLPOWERS have a MC4 cable example over here :
UWBCMS6
www.allpowers.net
So you could either use MC4 connectors,
or the Victron quick disconnect or others as you see fit.
hers the othyer option thge do for power power panels.
UWBCMS6
www.allpowers.net
Generally I use MC4 for solar panel sides and Anderson Connectors for Power sides.
the CTEK has its own intermal MPPT controller, so you connect just the plain panel to it.
The ALLPOWERS again implies it has a internal controller and shows the panel directly connected to it..... BUT i believe its 50W MAX !
EDIT:
Solar Charger Input/Anderson Power Solar Input: 12V-22V/3.2A(Max.)
Allpowers offers a range of portable power solutions, including solar generators, outdoor camping RV portable power stations, home backup power stations, and solar panels. Recharge for a better life and empower a beautiful world.
www.iallpowers.com
Portable Power Station
Power up to 11 devices at the SAME time
11 POWER GENERATOR OUTLETS: Ready for home, camping, or commercial use - take the RIVER to camp, a photo shoot, for your RV or camper, and it can also be for portable CPAP power. Pairing no portable generator offers more energy delivery variety; charge cell phones, electronics, your car and more.
comes with an AC wall charger and 12V car charger so it’s easy to recharge RIVER wherever you are. Solar chargers are also available for purchase!
- Specification:
- Battery Capacity: 372Wh/105000mAh
- Rated Power: 300W, Peak Power 500W
- Output Waveform: Pure Sine Wave
INPUT:
AC Input: AC 110v/60Hz 2A
(please use the adapter included with this generator)
- Size: 20.6x16.5x11cm/8.1x6.5x4.3inch
- Weight: 3986g/137.3oz
the CTEK as shown above has a max VOC of 23v
so a 50W panel may be max for the ALLPOWERS and as 100w panel may be max for the CTEK,
so you could get 2x50W panels,
use 1x50W for the ALLPOWERS and then use 2x50W (in parallel) for the CTEK.
But think it will be more efficient to just use a 100W panel connected to the CTEK, then charge the ALLPOWERS via the 12V input?
unless you NEED to use the ALLPOWERS OFFGRID, in which case you need a 50W panel.
like these :
ALLPOWERS offers a range of portable power solutions, including solar generators, outdoor camping RV portable power stations, home backup power stations, and solar panels.
www.iallpowers.com
