fendale2000
I've had a T6.1 for a couple of years and the tailgate has always closed fine. A few weeks back it stated misbehaving. This is not a "soft close" or electric tailgate - just the old fashioned slam it down type!
When I close it now, it kind of bounces back slightly and doesn't close tight. When I lock the van, it does lock, although it still jiggles if you try to open it. When driving the MFD shows the tailgate as open.
I have a suspicion it could be the locking mechanism on the tailgate, but I have no other vans to compare it to.
With the tailgate open, I can push the mechanism around and it clicks once and latches, but I can still push it around further but it always springs back to the initial latched position. Its as if the locking mechanism is refusing to hold in the fully locked position and is partially locked. Does that make sense? If so, is this likely a failed locking mechanism, and if so is it easily replaced? Van is out of warranty, so I'd rather avoid giving it to VW!
As I typed this, and was playing around with it I accidentally closed it while it was in the locked position, since doing that (probably the bump I gave it), I can actually push the latch around so it clicks a second time in what looks like the fully locked position, but the mechanism seemed to be struggling to unlock it again. Then I stupidly closed it, and its now stuck closed and won't open at all. Sigh. The back of the door has a trim panel on it, so I guess I will have to try to take it off and see if it reveals some way to unlatch it from the inside.
