T6 virtual cluster from aliexpress
Congrats to the owners... looks awesome! I'm hunting for it as well for a while but on ali there are two versions sold: 10,25" (Carcluster Lcd cyfrowy zestaw deski rozdzielczej dla VW Caddy Touran Transportor T6 EOS Sharan Golf 5. wirtualny panel przyrzÄdów. Kokpit - AliExpress 34) and 12.3" (Wowuseful 10.25 Lcd Digital Dashboard Cluster dla VW Variant Caddy Touran T6 EOS Sharan Golf 5. Wirtualny instrument Paneel Cockpit - AliExpress 34). Here from pictures and video they looks same however seems that both versions were present. Is that true that it's the same version or there are two different?
Get the wowuseful direct from their store on ali express! Just make sure you select the T6 on purchase. They did message me before sending to confirm my vehicle
Hi All, I’ve just fitted mine in the van and all working ok. I got an update from the engineer today and installed. Not really sure it was a good move. It removed the multivan option in the car choice menus. It also still makes random calls when phone is connected with Bluetooth to the discovery media unit when changing setting on the cluster.
I have a quick question regarding fuel level. Can someone please explain how to set this correctly. My van was a little under full when I installed it and I’ve put the tank capacity as 70l.
Am I right in thinking that I need to do this again when I’ve brimmed the fuel tank? I thought it would pick it up automatically and read the actual level that’s in the tank.
2017 T6 204 4-motion
I've made plenty off accidental phone calls when playing around in the settings too, I switch bluetooth off on my phone now when I want to change something
Can you view navigation etc on the dash?
It’s a big ask but can you send a photo or a video if it does work ?
You can screen mirror your phone to the nav screen on the dash, if the sound plays through the dash, turn the volume down and back up on the stereo to redirect it
and you don't have a bigger tank? look at the number of liters in the tank, it shows the condition and how much is missing
Installed and reverted today o_O
Installation was pretty easy, the only thing that I found nasty was that prying the needles from the old cluster leaves little bit of marks. Perhaps should have used a thin cloth or something to protect the base - removing the needles requires surprising amount of force.
Take care to not lose blinker films, they are loose and just drop out easily.
Removing the needle motors is easy, just push the center pin down with a thin spike, eg SIM tool and then the motors can just be popped off. Getting them back is slightly trickier, from the other side you need much longer thin tool to push the pin back - I used a pogo pin as I had those laying around.
The virtual cluster has a small (2-pin?) unpopulated mystery connector on the board and a HDMI connector hidden under warranty void sticker. I could not get this HDMI to do anything - probably it’s disabled in firmware. It would have been an interesting input to feed something from eg a Raspberry PI. Perhaps the same can be done through the USB but I think it will need yet another worm box for signal conversion.
Why I reverted? When I fired things up, I got the virtual cluster to work fine. But… car would not start anymore and I got huge amount of DTC’s - including engine disabled by immobilizer. Ok so problems with talking to the original cluster motherboard. I then reconnected all connectors couple of times. After this I got a bunchload of beeps and no virtual cluster anymore… most likely just some contact issues. But as I need the van running tomorrow I decided to leave looking into it until I can spare a day or two without a van and properly check the loom.
Here my version numbers which works fine but I'm considering reverting back due to lack of ability to control phone calls through MFSW. Details on the other thread.
Finally got round to fitting mine. Not had a good play with it yet. I feel it needs a Matt overlay on it as the screen is very shiny. Anti glare laptop screen protector on its way.
I'm so tempted as I've just got the bog standard HU in mine so no nav display and even if I upgraded the HU I still think I'd prefer the sat nav dsplay right in front of me.
Prices seem to be changing constantly and it's risen quite a bit since the OP.
What did you pay total @Deaky?
I was in the same boat with no factory nav. Only negitive i see this way is you still need to set it up on your phone. Regs price, once you add the tax, i just elected to buy from Everest VW for simlar money in the UK without the hastle factor of ordering from China.
