Hi y'all.
Well - shite. Asking for help here as the van is stuck where it should not be!! It's a 2017 T6 102ps panel van.
I did a simple hardwire install of a dashcam today. When I went to start the van afterwards, it turned over a few times and then was dead. Ignition now does nothing. No lights on dash. MFD does show doors are open and interior lights are working when doors open.
I have checked all the fuses I can think on on the fuseboard by the gear stick - all seem fine. 5A BCM okay (swapped out just to be sure) ... bigger ones for ignition also seem fine.
I have tried disconnecting the battery and then touching pos and negative cables together.
I didn't disconnect the battery when doing the work - probably should have.
In the install process I removed a TomTom that was behind the glovebox - this was just wired to the fusebox IGN and 12V+ with standard aftermarket push in pigtail things - so it seems highly unlikely this is the cause. (van used to belong to a big company).
I also tidied up the remaining loom that had connected a Trimble tracker. The tracker itself was removed weeks ago with no issues. The remaining loom was a OBD pigtail interface which had allowed the tracker to splice itself into OBD to monitor the vehicle while providing a second OBD port for diagnostics. I removed this - leaving the original OBD port. The only thing I changed was to remove a single fused cable which ran from the tracker loom and spliced to a very thin cable on the headlight angle adjuster control. I assume this was to monitor ignition status. I have put the loom back the way it was and reconnected that single cable, but this hasn't changed anything.
It seems unlikely that I somehow triggered the immobiliser by removing this cable (which wasn't connected to a device)!?
If there is anyone out there in the cold reading this that has a suggestion, please do make it - the van really shouldn't be where it is come morning!
My next move is to check the relevant fuse locations for voltage before going to the main board under the battery. Not sure what to look for there.
VCDS says the instrument cluster is not communicating and immobiliser has stopped engine starting. Have I somehow shorted a fuse to the cluster?
Many thankyous for any help
I get this from VCDS:
4 Faults Found:
25577 - Engine Start Blocked by Immobilizer
P1570 00 [10100011] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 204699 km
Date: 2092.01.26
Time: 16:49:45
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 3 °C
Intake air temperature: -5 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.562 V
Unlearning counter according OBD: 40
Immobilizer Snapshot 001 Byte 1: 14
Immobilizer Snapshot 001 Byte 2: 00
Immobilizer Snapshot 001 Byte 3: 0A
Immobilizer Snapshot 001 Byte 4: 03
Immobilizer Snapshot 001 Byte 5: 10
Immobilizer Snapshot 001 Byte 6: 00
Immobilizer Snapshot 002 Byte 1: 00
Immobilizer Snapshot 002 Byte 2: 00
Immobilizer Snapshot 002 Byte 3: 00
Immobilizer Snapshot 002 Byte 4: 00
Immobilizer Snapshot 002 Byte 5: 00
Immobilizer Snapshot 002 Byte 6: 00
Immobilizer Snapshot 004 Byte 1: 00
Immobilizer Snapshot 004 Byte 2: 00
Immobilizer Snapshot 004 Byte 3: 00
25809 - Power Steering Control Module
U101D 00 [00100011] - No Communication
[Power steering control moduleNo communication]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 0 km
Date: 2092.01.26
Time: 15:25:35
Voltage terminal 30: 11.601 V
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: main switch off
selected gear: Shifting process active
25810 - No Communication with Instrument Cluster
U0155 00 [00100011] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 204699 km
Date: 2092.01.26
Time: 15:25:55
Voltage terminal 30: 11.898 V
25811 - No Communications with HVAC Control Module (J301)
U0164 00 [00100011] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 204699 km
Date: 2092.01.26
Time: 15:25:54
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 204699 km
Date: 2092.01.26
Time: 16:49:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 0 km
Date: 2092.01.26
Time: 15:25:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 204699 km
Date: 2092.01.26
Time: 15:25:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Mileage: 204699 km
Date: 2092.01.26
Time: 15:25:54
