T6 tow bar wiring
gbates
Hi all,
Appologies is this has already been covered but has anyone fitted the PF jones 13pin tow bar wiring loom and how did they do it? Reading up on here people say to take it under the passenger seat to the fuse box then on to the BCM but the instructions say to take it up to the main battery and install a 2nd fuse box included in the kit there. It doesn't show it being connected to the body work either which I read should be done.
Its the PF jones specific kit for models 11/19 onwards. Im beginning to wonder if they have changed it slightly from the T6 kit. Having a look at the westfalia kit that also shows it going under the seat but I wonder if thats the T6 not the T6.1 kit also.
So far have rodded the cables above the fuel tank and up into the engine bay.
Any advice appreciated as I seem to be reading different things each time.
Thanks George
  • 29270574PF-VW-T6.1-19.pdf
Looks the same as ECS kit. I had a permanent 12v of decent guage under passenger seat so installed my 3 x fuses there in original VW fuse holder. I then pulled can connections under carpet to drivers footwell area before taking up to BCM.
