I'm not sure that works pal, think THQ tried it. On the 3 sets they gave away for testing, 2 were fine and 1 sent the error code.I believe the issue can be cured by using VCDS to set "LED lights installed", but given that not everybody has access to VCDS, it is not technically a plug and play solution.
It's the auto headlights throwing the error code onto the bcm.
The other two models had auto headlights, but we're lower spec vans (startline) etc so not too sure.
