T6 THQ Full LED Headlights
These look great.
I’m almost convinced enough where I might flog the OEM set sitting on the shelf that I haven’t got the guts to fit and get them to stick a set of these in.
Oem every time mate.
Hi just fitted some Gbrite led headlights. i have an aftermarket auto light switch fitted as well.Can anyone with these lights tell me how they are working on their van
on auto both single projectors are lit. On sidelights switch is green but no lights on. Main beam both single projectors are on. high beam all four lamps are on, is this how they are suppose to function i was hoping they could be coded to be the same as the thq ones? both lamps on & just get brighter with high beam on 🤔
sounds like mine, side light is the same as the dlr light, but dimmer iirc
edit. on auto they run on dlr, the projector on comes on when it gets dark
Ah ok at least i know they are working the right way i wonder if they can be coded like the thq ones seems odd the only way to have all the lamps on is only with high beam
Does anyone here suffer with DAB poor signal after fitting these headlights?
Over on the Vland thread a lot are suffering with poor DAB signal after fitting the Vland headlights.
I’ve been watching that, but I have never had a great dab signal in the van so been wondering how they can tell, I thought that was normal. Certainly haven’t noticed it being any worse after the lights were fitted
Simple answer in no but i do have a Kenwood headunit and shark fin on the roof from @Absolut5 .
LOL to be fair the signal isn't that great on the VW radio...
