Are you going to be converting it to a camper? The T32s very harsh and crashy as an empty van, but when you get permanent weight in the back that might change.
It might be worth speaking to CRS for some advice and options, even if you don't want to lower it Steve could give you some spring/damper advice.
After many months of debate on the best low suspension for the Transporter buses, we have eventually taken our development to another level.
Over the last 6 months we have shown that probably the best all round kit with sensible drops is the KONI shocks and H&R spring kits (correctly spec'd).
We have now had the opportunity to tackle the big drop scene and back to back test the ever popular B14 against a similar H&R/KONI set up.
Here is the story :-
A Forum member called to discuss his needs and ask what we thought was the best way to run his van low and drive well. After a long...
Very pleased today ...had fitted Koni dampers fitted with EBC yellow stuff pads ......Quick..Friendly..and listen’d to my needs......my T32 204 auto had a habit that it wanted to lift the front end and spin the wheels when pulling away (Steve. Recommended adjusting the lift on the dampers ...early days yet but big improvement and the new pads help with brake fade)
There are few things you can do to get a better ride from a T32 , it will be beneficial to call us and listen to some sound advice . A combination of the right springs and more importantly SHOCKSs and you will be amazed at the difference
Hi Guys,
Looking to get my suspension changed on my T6. I know CRS have a great rep on here but they’re 4 hours drive from where i live. Can anyone recommend someone near me, i live in Kent not far from Folkestone? Many thanks in advance
Hi Guys,
Hi Guys,
@Timbo89 I'd make the drive up yourself and be with the van while the suspension is being fitted at @CRS Performance then you can be on hand to make any decisions should any other parts need changing or to answer questions on how you'd like the van to sit etc. It'll be worth it in the long run as you can have it fitted and any issues resolved on the day rather than going backwards and forwards. I am another happy CRS customer with a Koni Definition kit which I thoroughly recommend but I'd give the same advice if you were to use any other suspension company such as @Dav-Tec or @BognorMotors. I think it'll just be easier overall. As @Dellmassive says make a day out of it and have fun on the way back.
Get a lift kit fitted by a suspension specialist. My T6.1 came with lowered springs and struts (low profile tyres) and I hated it. Felt every little bump.
The lift kits added 100mm (40mm from standard) and is a much smoother ride.
I will tolerate the low profile tyres till they wear out and I will get bigger tyres that now will fit.
