T6 Rear Door Handle Broken
Braddabing
Hi all
So on the one and only night we’ve slept in the camper so far, it was frosty outside and the external mechanism seems to have snapped… (still opens from the inside)
I’m fairly competent with a screwdriver and a set of Torx so wanted to know if this is a simple job and if there is a part number I can cross reference before I take it off and leave a gap in my door.
Also, if there’s a better replacement, happy to hear suggestions.
Cheers.
Sometimes if you are lucky - it might be a little rod that has disconnected itself.
It might be worth seeing if you can get to the innards before buying anything.
Didn’t even think of that. Do you know if it’s a case of removing the trim on the inside of the door to have a look? Or do I get at it from the outside? Thank you!
