T6 LED reverse bulb change now issues with reverse camera
DW84
Hi All,
First post so go easy on me
It's a T6 - 2018.
I've just changed the reverse light bulb to an led version this afternoon. Standard one is shocking.
I'm running a Kenwood GARMIN DNX518VDABS and it has a reverse camera. When I go into reverse now with engine running the camera no longer works and there is a loud buzzing noise from somewhere in the dash.
I did a search of forum and found that it will be relay related. I also looked through the downloadable wiring guides. I bought the HEF560 relay with diode from Halfords.
Please can I have some advice on where this is likely located for me to change? Is it likely to be with other relays or behind dash by Kenwood unit?
Thanks - DW
Alternatively you could consider software modification via VCDS, OBD11, etc.
Yes, PWM can be individually switched ON or OFF. To switch OFF PWM for reversing lights Byte 11 bit 4 needs to be deactivated(unticked) in BCM(address 09).
