dhod
Hi all,
My first post here - been reading and soaking in as much as I can over the last few months as I'm just starting out on my own conversion project.
The Van
VW T6 (T30) - SWB - 2018
The Plan
Every guide you look at seems to recommend doing things in a different order so some of this is still work in progress or subject to change. I've tried to break the conversion down into 10 milestones (even if some can be done in parallel)
I figured there was little point in doing anything else until this is done
Dodo Thermo Fleece 50mm Slimline
Dodo Thermo Liner Pro 10mm (10m roll)
Silent Coat 2mm Large 80 sheets
To Decide:
100mm Thermo Fleece (Dodo or Otherwise)
I struggled to find any of the 100mm in Dodo but found lots of other "ecotech" kind of thing. Unsure if the 50mm will suffice or if it's strongly recommended to get some 100mm for some of the cavities
Figure out what on earth i need to do here
Electrics seems to be the one that people sometimes do right at the start or towards the end. Would appreciate as many guides/videos/recommendations here around what to do. I don't plan on powering anything huge beyond a fridge (more on that later). No TV, no microwave. Would like the option to be able to connect up to a campsite's hookup though so will look to have some sockets and usb sockets
To understand:
Will this work with a pop top?
Do i need to buy 2x 100w and have one fixed to roof and one portable given the angles of the pop top?
Figure out if i’m better off having leisure batteries (i've seen a big push towards lifepo4) to hold the charge or something like a goal zero yeti? And how to work out how much is enough as £500 a battery isn't cheap)
Need to learn about all the chargers, mppt's etc.. a whole world to learn about basically!
Purchase pre-cut 12mm plywood for floor and 6mm panels for walls
Due to weight considerations probably opt for vinyl floor vs wood.
Unsure what to do with walls after plywood attached.
Mainly for saving the hassle of intricately cutting out all of the necessary shapes and sizes of a t6 by hand. £250 for the full kit doesn't seem like the worst expense in the world?
You are being redirected...
Questions:
Is it safe to buy second hand or should I buy new?
Buy and cut foam bedding
Install water tank around wheel arch?
Decide whether to get a fridge or a good coolbox
Figure out what to do about a portable toilet
Questions:
Waste tank needed or hole will suffice? What happens with insulation/noise?
Stove, gas canister
Kiravan side door panel
Space saving bits
etc
That's where i'm at so far. What do you all think about the order - anything you'd recommend changing or potential pitfalls i'm walking straight into?
The Van
The Plan
Milestone 1 - The Roof
Aurora Roof - Being handled by Jay at xtremevans early next month.I figured there was little point in doing anything else until this is done
Milestone 2 - Sound Proof & Insulation
Already Purchased:Dodo Thermo Fleece 50mm Slimline
To Decide:
Milestone 3 - Electrics
Plan:Figure out what on earth i need to do here
Milestone 4 - Solar Panels & Batteries
200 Watt 12 Volt Monocrystalline Solar PanelTo understand:
Milestone 5 - Floor and Walls
Plan:Purchase pre-cut 12mm plywood for floor and 6mm panels for walls
Milestone 6 - Heating
I'd really like the option to be in Europe in the winter (and i live in the UK) so figure getting a diesel heater is an absolute mustYou are being redirected...
Questions:
Milestone 7 - Furniture
Plan is to make this all by handBuy and cut foam bedding
Milestone 8 - Water
Install sink and water pumpFigure out what to do about a portable toilet
Questions:
Milestone 9 - Finishing Touches
reupholster the seats and bedStove, gas canister
Space saving bits
etc
