Almost completed the electrical install in our Caravell. It’s been a lot of work, countless hours researching, solving problems and testing.
The install consists of:
110 AH AGM Leisure battery
CTEK D250SE
Victron Battery Protect
Victron Smart Shunt
Victron 250W Inverter
Victron 75/15 MPPT
Victron Smart Charger 15AMP
240V consumer unit plus sockets
learnt this trick for removing the Plenum cover from Comb Valley Campers:
Although I discovered I could not use the grommet in the Plenum Chamber as it was used for the sunroof drain!
The MPPT controller is only attached to the CU via a Magnet so I can remove it. The Victron Smart Charger is also removable.
Under the passenger seat I managed to fit the CTEK / battery / Victron Smart battery protect and the Shunt as well as a 6 way fuse box and battery isolator:
Fitted USB and 12V sockets to the seat bases. Also moved the original C and D pillar 12V sockets power supply to the leisure battery
Under t(he drivers seat I managed to fit a Victron 250W inverter, 6 way fuse box, Victron Battery Monitor etc. It was a tight fit with the factory fitted Panasonic Power amp for the DynAudio setup
I‘m not fitting solar on the roof at this stage, I’m happy with the Lensun 200W Portable panels. I can connect them to either the CTEK MPPT Port or the Victron MPPT Which is connected to the starter battery. That gives me options.
And finally a diagram
CTEK D250SE
Victron Smart Shunt
Victron 75/15 MPPT
