Hi,
wonder if anyone can help, or suggest what to look at next.
Went out yesterday, and whilst away my van wouldnt start, with no crank. Ended up tow starting it, turned off stop/start and drove home.
Today. van still wont start, with no crank. Checked in VCDS that clutch is detected, yup. Battery, over 12V.
Tried back feeding the starter, with ignition switched on, and clutch pressed. Cranks, no start. Also tried with key turned to start, still no joy. Logs fault code of circuit 50 short to plus. Flashes glow plug light.
Not sure what else to try, or look for. Testing the relays next.
Had a previous issue with signal wire between battery sensor and alternator not communincating so no stop/start. Fixed wire didnt see any other broken wires, stop/start working again. Was a month ago.
Had an EGR problem with van very difficult to start, around a month ago, replaced breather pipe, cleaned cooler, VW fuel additive. Van started fine after a couple of tanks of fuel.
Thanks for any help.
