Greetings everyone
I have a yellow EX AA T6 2litre 6 speed manual which ever since it's turned cold has an intermittent starting issue.
From cold if I go to crank it, it will just turn over and over sometimes it'll sound like it's trying to start other times it just turns over and over but then sometimes it will fire straight up and run absolutely sweet.
Unfortunately I don't have access to VCDS which I think may aid me further
Cam and crank sensor working and in sync virtually figure wise
All fuses have been checked
All earthing points have been thoroughly cleaned same with earth leads
I'm off down into the E Hub today to check glow plug wiring to see if I'm getting voltage there as it's definitely temperature related.
A few months ago I replaced the following parts as they where needed, new yuasa EFB battery, X3 glow plugs except the pressure sensor one as no where had one in stock, timing belt & water pump, full service kit.
Recently I've replaced fuel temp sensor, wiring where it usually breaks not far from the sensor and new plug all from TPS.
Had to re-do the timing belt and water pump due to a leaking water pump 400 miles after it was done
New starter motor yesterday as the old one was a bit sluggish at turning over.
Can anyone offer any aid at all, I am a technician by trade however this one is stumping me massively and I really need my van back! Any helps would be very much appreciated
Regards, Levi.
Regards, Levi.
