T6 2017 model combi central locking issue
wellchewed
Hi all , Had a my t6 a while love it never had any issues. But just out of the blue my rear tailgate stopped working from the handle at the rear.
What i mean is when you grab the handle and the vans unlocked the tale gate should open now nothing.
So i removed the door handle and actuator and it was wet inside.
So toke it apart dried it all out , tested the handle micro switch all fine , Tested the actuator all fine. Great put it all back together.
Still not working , After further investigation my side door is also not working on the fob , I can lock and unlock with the key fine and use the side door.
My tailgate will not open at all from the handle but i can pop it open from the inside as i have the door card off
I can use my side door as long as i remember to lock and unlock the door with the ley fine.
Nothing happens on both my van key fobs when i press them in regard to those 2 doors only the tail gate and the side door.
My front doors work perfect on both keys.
I have checked every single fuse i can find in the van with not a single problem
I have ran through a number of key reset and re-sync processes i found on the internet.
Im stumped , anyone had this before ?
Its a 2017
T28 2.0 TDI 102 BMT T/L SWB​
I've got the same problem. Guessing a sensor. There was water getting in there somehow. I guess it has something to do with that. Did you sort it out?
