C Creamytash Senior Member T6 Guru 18 Jan 2024 #1 Can anyone tell me if the front and rear suspension from a 2020 plate T6.1/T30 will fit a 2014 T5 please. Thank you guys Creamytash
T The Bear78 145 000 miles and just broken in! VIP Member T6 Guru 19 Jan 2024 #2 T5.1 I assume and is it also a T30? @BognorMotors Last edited: 19 Jan 2024
C Creamytash Senior Member T6 Guru 19 Jan 2024 #3 The Bear78 said: T5.1 I assume and is it also a T30? @BognorMotors Click to expand... Who mentioned a T5.1???
T The Bear78 145 000 miles and just broken in! VIP Member T6 Guru 19 Jan 2024 #4 If its a 2014 van it will be a T5.1.
The Van Cave VW Bus Modification Specialist Trade Member T6 Legend 19 Jan 2024 #5 If you fit the springs and shocks from the T6.1 into the 5.1 then yes, no problems. You can’t use just the springs or just the shocks as the T6.1 front springs aren’t compatible with the T5.1 front shocks and vice versa. Both vans also need to be the same fitment, so either both must be T32 or both must be T30 or lower.
C Creamytash Senior Member T6 Guru 19 Jan 2024 #6 The Van Cave said: If you fit the springs and shocks from the T6.1 into the 5.1 then yes, no problems. You can’t use just the springs or just the shocks as the T6.1 front springs aren’t compatible with the T5.1 front shocks and vice versa. Both vans also need to be the same fitment, so either both must be T32 or both must be T30 or lower. Click to expand... Thank you for taking the time to give me a sensible comprehensive answer, I do appreciate it. Creamytash
