T6.1 Shuttle 2020 Rear Air Con
jon1979
I have a problem where front drivers area is getting air con but rear is only getting ambient air on the cold setting. I am thinking the blend motor is faulty but no idea where this would be if anybody can help? Photos of controls attached.
Stupid question, are you sure it has rear aircon? I am guessing it must have as havent seen a fancy console controller like that. Simplest way to check is in the engine bay 4 pipes and not 2. Some dont have full aircon in the back.
Hi. Yeah it only has two pipes in the engine bay so have been told no rear air con. A really stupid design as it has roof vents in the rear lining but no windows to open.
I may be wrong, but I think you only get rear AC on models with climatronic (Climate control) - the ones where you set the temperature on drivers side and passenger side, and the rear. Available on some shuttles, caravelles and californias.
As has been said. Air con was an upgrade on shuttles. Madness as the rear gets really hot, as you’ve found out
