T6.1 Black door cards
No, on the right card it's that cut out on the bottom right above the storage bit.
Looks like two different style door cards there. The one circled is for adding a silver trim like in the california etc with silver door release handle. The door card on the left looks like a standard one as that just gets the standard grey trim but with grey door release handle
Makes sense! I might try and swap the door handles over now I have the cards. Do you happen to have to part number or name for that silver trim bit off the calis?
Good luck. They are plastic welded in place. Don't you want them both to have the silver release handles? Just seen your other post and looks like you have one bog standard one and one high spec one.
Ill have a look. There are two types. Brushed silver which I have or a silver with a black hex pattern on it. They are £90 each!
I'm happy to re-plastic weld the handles mate, if you have the part no or a link to the little silver trim and the handles in silver that would be much appreciated!
See previous post, link and numbers.
Unfortunately you can't buy the release handles as a part, only with the complete door card.
Plain silver which I got was 7LC868040YP2
When I got a price from VW Van Parts direct (part of Fish brothers) after sourcing my lower black trims this is what they came back with:
Satin Black options for the front door cards and trim:
Main Door Card - £291.60
Trim - £98.40
Prices inclusive of VAT - £6.95 for delivery.
Black lower dash parts as follows in case of use to someone.
W Transporter 2020 Onwards Centre Console Trim (Titan Black) (#7L2857771E82V)1£143.56
VW Transporter 2020 Onwards Dashboard End Trim Left (Satin Black) (#7LA858217 82V)1£15.99
VW Transporter 2020 Onwards Dashboard End Trim Right (Satin Black) (#7LA858218 82V)1£15.99
VW Transporter 2020 Onwards Glovebox (Titan Black) (#7L2858007E82V)1£151.99
VW Transporter 2020 Onwards Instrument Panel Trim (Titan Black) (#7L2858903A82V)1£60.46
VW Transporter 2020 Onwards Trim for Air/Heater Controls (Titan Black) (#7L2857200AOZS)1£126.08
VW Transporter 2020 Onwards Trim Panel for Dash Panel (Titan Black) (#7L285713582V)1£24.53
Subtotal:£538.60
Trim - £98.40
Subtotal:£538.60
Did you ever get the part number for the main door card? Looking to do this on my T6.1
Thought I'd help out here as I've done full lower dash and door cards. This has the door card part numbers on for you.
For reference this list is everything you need for lower dash in tian black apart from the section surrounding the heater controls ( I had one of our guys paint it as the section that is actually titan black is very small and the main section we repainted gloss black anyway)
Here's a few pictures for you for reference to show colour difference to.
Your a star! Thank you very much
I
Wow. Looks great Wish I'd done all that now as I've changed all those pieces except glovebox and center section to add in the silver trims. Wouldn't have cost much more either.
That's great info.
However I noticed the first item in the list (the instrument panel trim - 7LR 858 903B UUS) says Titanium black / pewter weave, whereas all the other parts are Titan Black.
Is there a different part for the titian black instrument panel trim?
That's great info.
This is the item in only black with no trim option. Just simple black - 7L2858903A82V
This list will give you JUST black no options of pewter or carbon etc etc
Subtotal:£538.60
AND if you want simple black door cards with black trims that are the same style as the light grey ones around the grab handle then these are the items:
W7LH867021A 82V FRONT DOOR PANEL - 243.00
M W7LH867022A 82V FRONT DOOR PANEL - 243.00
M W7LC868040 YP2 FRONT DOOR TRIM -103.50
M W7LC868039 YP2 FRONT DOOR TRIM -103.50
Thanks, much appreciated, however I prefer the parts with with the pewter (?) trim on that @chris3125 has in his photos rather than the plain black.
Also I notice some of the parts you listed are Titan black and some are Satin black. Now I'm thinking would they match?
