Full set of grey hardboard panels might be of use to someone before they get recycled. The rear panels are half height. Reasonable cosmetic condition but well suited for templating purposes.
9mm ply floor in 2 sections (split lengthways) which was in the van when I bought it. Has the 6 holes cut for lashing. The top is grubby and has some double sided sticky tape stuck on that I used to stick Lino. Perfect floor if you plan on covering it…
Based in S/W Sheffield. Be good if this can be of use to someone rather than disposing of.
