Please help, I tried fitting a new head unit, I shorted a wire and now the van won’t start.
At first it would start but then cut out seconds later, now I have no electrics at all..!!
tried all Fuses in side and in the engine compartment.. Carista throws this up..
DETAILED ECU INFO
ECU info obtained with Carista 502199 for iOS:
VIN: WV1ZZZ7HZHX0*****
Engine
Part #: 04L906056KL
Component: R4 2.0l TDI
Coding: 00194014432401090000 (hex)
Fault codes:
25577 Manufacturer-specific code
25797 Manufacturer-specific code
25809 Manufacturer-specific code
25810 Manufacturer-specific code
25811 Manufacturer-specific code
ABS
Part #: 7E0907379P
Component: ESC
Coding: 517E4098256484818A7D027DA48921E6790000 (hex)
Fault codes:
00166 Access/Start Authorization Switch (E415)
08279 Manufacturer-specific code
08281 Manufacturer-specific code
08295 Manufacturer-specific code
08297 Manufacturer-specific code
08329 Manufacturer-specific code
Instrument cluster
[ECU not present]
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Coding: 000000000000000000000000000000003231 (hex)
Fault codes:
12670208 Manufacturer-specific code
12674816 Function Restricted due to Missing Message(s)
Steering angle
[ECU not present]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Coding: 10800A (hex)
[No fault codes]
Heater & air conditioning
[ECU not present]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Coding: A0A4303A0A61343193284F746CEB9E7C0F84708F60CC6D60320400220840 (hex)
Fault codes:
03430 Manufacturer-specific code
01758 Bulbs for Brake Lights
00532 Supply Voltage B+
01332 Door Control Module: Passenger Side (J387)
01331 Door Control Module: Driver Side (J386)
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
Fault codes:
03158 Control Module for Information Electronics 1 (J794)
Immobilizer
[ECU not present]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B7A73 (hex)
[No fault codes]
Infotainment system
[ECU not present]
Obtained with Carista 502199 for iOS.
Download app: Carista OBD2
Facebook: Carista
DETAILED ECU INFO
Engine
Part #: 04L906056KL
Fault codes:
ABS
Part #: 7E0907379P
Component: ESC
Fault codes:
Instrument cluster
[ECU not present]
Airbags
Part #: 7E0959655G
Fault codes:
Steering angle
[ECU not present]
Part #: 7E0919475T
[No fault codes]
[ECU not present]
Central electronics
Part #: 7E0937090B
Fault codes:
CAN network gateway
Part #: 7E0909901
Fault codes:
Immobilizer
[ECU not present]
Battery regulator
Part #: 7E0907534
[No fault codes]
Infotainment system
[ECU not present]
Facebook: Carista
