That 20mS changeover time for Victron is just the time constant for a 50Hz supply ie. the one cycle behind the mains that any UPS would have to use as a reference to follow the mains and not be out of phase with the supply when it cuts in to export.
Doh!!! Why didn't I think of insulating the batteries like this????Here we are @Dellmassive
First the Inverter panel then the Batteries, in summer and winter mode. The insulation boxing makes a big difference in the winter and is easily removed when the weather is less cold
View attachment 321162View attachment 321163View attachment 321164
It's not so much a super fast reaction so much as the shortest the gap can possibly be as the incoming supply frequency effectively calls the tune which in this case is a 50Hz sinewave and anything else coming into this has to follow by at least the one cycle (0.02s) anything at a different frequency or out of phase will cause major problems.Yeah, I guess the important thing is that it’s short enough that even sensitive stuff like computers etc transition seamlessly.
Fyi... This is the G98/G99 spec/standards that the grid tied inverter must confirm too.It's not so much a super fast reaction so much as the shortest the gap can possibly be as the incoming supply frequency effectively calls the tune which in this case is a 50Hz sinewave and anything else coming into this has to follow by at least the one cycle (0.02s) anything at a different frequency or out of phase will cause major problems.
I think it is just what they do, being linked by Wi-Fi to Ecoflow App.
You should be powering the rest of the Shire with a roof that size @Dellmassive is powering 60% of Romford with just 12 panels.I'm watching this closely, it's a very interesting thread. I have a big fibre cement sheet shed roof (25mx12m) which seems to be in the sun most of the day on sunny days, but things seem to be changing rapidly and I don't want to get lumbered with yesterday's tech, anything I spend will need to pay for itself in money, I'm not spending money to look virtuous.
You should be powering the rest of the Shire with a roof that size @Dellmassive is powering 60% of Romford with just 12 panels.![]()
Portable might be the way to go.....I'm watching this closely, it's a very interesting thread. I have a big fibre cement sheet shed roof (25mx12m) which seems to be in the sun most of the day on sunny days, but things seem to be changing rapidly and I don't want to get lumbered with yesterday's tech, anything I spend will need to pay for itself in money, I'm not spending money to look virtuous.
Hope so.More learning....
My Smart Meter is showing a small 'export'
However I can't get payment as plug in solar needs MCS certification. If you plug into the mains, it won't pass. If you get an MCS engineer to hardwire as per current UK regs, then you should get an MCS certificate and Building Control Completion. You can then apply to your Enrrgy Supplier who will notify the DNO and get the MPAN Export number.
It's mooted that come true Balcony Solar plug-in coming soon to the UK, the regs will change and the export process will become smoother.
Til then, batteries seem the only thing for excess solar generation or just let it go into the grid for free
The few of us with self-installs and use octopus managed so those self certification auction to get an m-pan and an official export....
Do you have info on that self-certification process ?
