++++++++++Is it right that if I plug batteries in to the socket to feed the house, I will always be limited to 800w.
The only way of getting more is to plug the appliances directly to the battery ?
What would be the way of getting more into the house ? Is this when the DNO extras come into play?to get more power - it needs to be connected by sparks to the house.
800w is the hard limit for plug in solar in EU & UK,
you wont see higher power than that as you need better cable and fuses etc.
to get more that the 800w limit - it need to be hardwired to the house by a sparks.
if you plan to export then you need a G98 approval - FYI - these hybrid inverters up to 3.6kw are already G98 approved, above that power you have the G99.
to export you need to get DNO approval and get the meter setup.
i started with a GROWATT, but quickly moved over to the SUNSYNK range.
take a quick look whats involved.
