Solar Sheds & Other Non-t6 Solar Projects - How We Done It -
Don't forget the load terminal of a Victron MPPT is very flexible too, worth using for at least the battery protection if possible.
The terminal is capable of switching the same load as the charger is rated for so of you're fusing the small inverter at 10A that could work, depends how long the memory of the timer lasts without power as you head into shorter winter days.
Must get on with my shed project, I'm trying to hunt down some decent 12v festoon lighting to run, most seem to be either very "Christmas Decoration" style or 24v.
These seem the sort of thing but these seem a bit spendy as I might need a few sets
I've now fitted a power meter, as the MPPT was the cheaper, non BT version. However these cut off when the voltage drops overnight. As it was a pain to remove the solar wires each time to reset the meter, I've now fitted a mini resetable inline fuse/breaker which makes the job much easier.
This sunny weather is smashing it for the solar.
We are seeing some perfect sunny days giving a perfect sun PV curve through the day.
It's now sunny enough to provide all the power we need to....
Run the house while it's sunny,
Fully charge the battery bank for over night,
And getting some export when the battery bank is full charged.
This means I've not switched off the overnight top up charge from the grid.
Id been slowly reducing the top up charge as the weather go nicer......
Screenshot_20250621_080129_Sunsynk Connect.webpScreenshot_20250621_080117_Sunsynk Connect.webpScreenshot_20250621_080103_Sunsynk Connect.webp20250621_080150.webp20250621_080229.webp20250621_080250.webp
@Grim Reaper now has a domestic solar setup.
He's posted some pics on the T6FORUM Domestic Solar group
Drop some pics over here Dave to show others your Victron setup.
Self installed system, 12 470W Aiko Solar panels on Fastensol mounts split into three strings of 4 panels.
These feed into three Victron Smart Solar MPPT 250/60 charge controllers, which charge a GobelPower 314Ah/16kWh battery. A Victron Multiplus II 48/5000 supplies pretty much the whole house with power,
only a few high current circuits are grid fed.
I have been off grid for 4 weeks now (21/06/25) and apart from having to avoid turning the kettle on at the same time as the oven or hob everything is doing as it should.
Still no progress on the shed project but I have managed to get the full export set up on the house battery, which includes months of getting the existing FIT solar system paperwork sorted out and on to metered export.
So now the house (mostly) runs off time shifted overnight electricity via the battery, most of the solar gets exported and I'm still getting the FIT generation payments. Running the EV has dropped the diesel bill a lot, without really making any noticeable impact on the electricity bill.
Realistically I'm going to break even around the 9 year mark of a battery with a 10 year expected life span, but it's fun and geeky to automate and track everything and having the whole house on battery backup is extraordinarily useful when your day job is full time remote working, if my network and power goes out it's not just missing The Traitors I don't get paid...
Having had our 7th powercut this year (thank you Northern Powergrid), I'm pretty jealous of your set up
It's not perfect, when you simulate a grid outage obviously it can pick it's moment and go off grid pretty smoothly - so much so that the hair trigger UPS on the main network doesn't notice.
When it happened in anger recently as luck would have it the EV was charging so the house battery was too and it had to swing from 5kw charge to around 4kw discharge and that's a big ask and the UPS was needed.
But certainly we're getting to the point of having house batteries big enough in capacity and inverter to do this as a solid side benefit.
Remember the EcoFlow 800w solar inverter.
Look what we have now a few years later from DJI.
The same argument for a UK install regarding the Mains connection.... But its perfectly safe.
The EcoFlow 800w unit started my domestic solar adventure.
Now we run a 8Kw inverter, 25kwh battery bank and 8kwp PV array.... Happy days.
And have now halved out leccy bill during winter. And reduced.yo zero in peak summer months.
I was down to 20% overnight (system stops discharging the battery at that point and sucks what it needs from the grid) but with clear blue skies and cold temperatures I'm expecting a good charge today. Already back up to 28% at 10:41solar.jpg
My solarshed is doing well this morning, although the Shepherds Hut water feed pipes have frozen solid overnight. Need to do some extra lagging on those pipes...
I know it's not DIY but it's been interesting to see the behaviour of the Powerwall3 in freezing conditions - you can definitely see it spend some time at 1.5kw charge to warm the batteries before switching to the 5kw (I load shift on the overnight rate as my older 3.6kw house solar is not sufficient)
I'm a bit disappointed about the couple of times it's made mistakes and not started charging early enough on cold nights, for an allegedly smart system the behaviours seem fairly basic and I have to add a layer of monitoring via Home Assistant.
Still trying to work out how to add some more solar to the as yet unused MPPT inputs on it. Has anyone seen edn gable walls done as I have one that is well oriented and unshaded, but it would need to be vertical mount and non reflective for the neighbours and the few people I've asked don't seem interested.
I've thought about adding a few panels during the winter to supplement the permanent panels, they would have to be vertical mounted on the front of the house between upper and lower front windows. Would look terrible but hey I can't see them from where I sit.
I keep thinking about adding some more panels like this but on the back of the house. But there are some pretty big trees in the field at the bottom of out garden that would cast shodows except when the sun is at its highest in summer so not sure the return would be worth it. My inverter has a second set of solar inputs as well.
I've had a quick search and can't find the answer to my query, so I thought I'd park it here.
We have a 4kW domestic solar installation approximately 12 years old. It's developed an earth fault in wet/damp weather that clears when things dry up. I want to do some fault finding and see if I can trace the problem, it's most likely water in either a panel or connector. I'm happy insulation testing conventional AC circuits and have all the usual gear, Megger/Fluke multimeter etc. But I know bugger all about testing solar. The system has 2 strings of panels that get up to around 600V dc on full chat.
So my main question is, can I use my "Normal" insulation tester which is 500/1000V ac output to test my solar panels?
Any pointers greatly appreciated.
