I have a 130w semi flexible solar panel bonded to the poptop, it’s connected to a Victron smart 12/75 controller. I’m currently out in Portugal at the mo & I’ve noticed that the panel voltage is dropping from around 19v to 10v when the panel gets warm, which is about 10.30am. So at startup in the mornings it’s chucking out 50-60w @19v or thereabouts, after a couple of hours the voltage just drops off a cliff down to around 10V, it isn’t gradual, it’s as if a switch has been.....err switched. I don’t think it’s a cutoff/over heat device or the voltage would be zero if the panel had disconnected, I suspect it’s a row of cells on the panel that has a bad internal connection. When it cools down in the evening it comes back up to 19V or so. Any thoughts?
