Just been looking at another van on the site, it’s a T5 with a poptop & roofbar prep. The guy has made an aluminium plate to pick up on the roofbar fixings & then bonded his panel to that. The ally acts as a heat sink & there’s ventilation underneath. Very tidy job. I’d do the same if I had the roofbar prep. Bugger!well im going to do it on mine, the idea being that the vinyl should be easier to remove (than sikaflex or double sided tape direct on paintwork).
so still "cheese-wire" the solar panel off . . . . . but then the idea is that the sikaflex is bonded to the vinyl and not the paint work, so hopefully should peel-off leaving the paintwork undamaged.?
then just a new piece on clear vinyl and stick on a new panel . . . . . thats the idea anyway.
when i looked into this before some said about will the vinyl peel off when driving . . . . some pros said that you can get a heavy duty clear vinyl . . . and due to the total surface area of the vinyl to paintwork it should be a solid bond for the life of the panel . . . ?
