Solar panel cables advice please
Pedro20001
Auto assembly technician
Morning all, does anyone recommend cabling for a 100w panel? looking at approx 5m run and connectors, thanks in advance
have a look here:
the pre-made cables normally come with one connector on . . (for the panel end)
enabling you to run through the vans bodywork.
then terminate the other end with either another MC4
or
a screw terminal into the solar controller. .
The panel I'm interested in has a circular rear entry, 4mm twin flexible cable. I am wondering if there's a reason I can't just crimp the extension cable running to the mmpt with normal flexible cable? There's not really a need to use solar connectors once the connections are done inside the van?
