Slight Knock/thud When Reversing On Full Lock
Jimmi
Television Lighting Engineer
As post says, it doesn’t happen all the time. Possibly happens more when under load ie. on an incline. But it’s happened a few times now so staring to get concerned. Has anyone experienced this? I should point out that I have a 4motion running 235 55 18
I have heard of a few with the same issue but thats on vans that have been lowered.
There are a few things that can cause such noises , INFO that might help are , How many miles on the clock , age , and any work been done on the car recently . is the suspension standard etc
It sounds like the ARB tie rods could be the cause , if this is the problem the best way to test is drive over a bump with only one side of the van , if one wheel is in compression and the other not this is when the ARB is being stressed and if there is any play in the ball joints it will click .
